LarryFine
- Henrico County, VA
- Electrical Contractor
Or a solenoid tester.winnie said:A 10W lamp from hot to ground should do nicely.
480sparky said:480's Recipe for finding the right breaker:
Ingredients:
1. Receptacle socket adapter.
1. Bulb flasher
1. 200W bulb
1. Ammeter
Insert flasher into socket, followed by bulb. Insert into receptacle and make sure bulb is flashing. Go to panel & remove cover, using ammeter to find a 120v circuit with amperage going up & down at the same rate as flashing bulb.
Lock-out breaker as normal, and continue work in safe fashion. When done with work, stop by local watering hole and quaff down a cold one before heading home to family.
Now that's what I call testing under load! :wink:brian john said:I have also used the flasher with 2-100 amp bulbs.
1.Receptacle socket adapter.
1. Bulb flasher
1. 200W bulb
1. Ammeter
Does that price include the "cold one"?480sparky said:Hopefully, you've already got the ammeter. For less than a 10-spot then, you're set to go!
nakulak said:(just made a small correction)
"tic" tracers
cschmid said:and one more time how do you label a link with you own text..
cschmid said:tell the truth too....
my way is probably not the correct way..I short the receptacle out..I have tried to wire trace it but when it gets to panel signal is all over the place..
infinity said:We used to do that too with old fuse panels. One time I was grounding a #12 THW to a piece of EMT and it simply wouldn't blow. After a few minutes of arc welding it finally blew. When I checked the old fuse panel I found that the insulator between the shell and the center of the Edison based fuse holder was missing. As was the 20 amp fuse. Turns out that I blew the 125 amp main fuse blew on the riser. The people down the hall weren't too pleased.![]()
Now we just use a circuit tracer.![]()
I do it the hard way:cschmid said:. . . and one more time how do you label a link with you own text..
It had something to do with cutting your romex half way and hidding it in a bored hole:roll:bkludecke said:I've used 480's flasher method for decades now and it works great.
One day quite a few years ago I was on a job and there was a real grumpy plumber working. I got to thinking and while he was taking a break I rigged up my little flasher in line with his extension cord. When he went back to drilling holes it was priceless. Then he figured out what I did - I'm sure glad he had a sense of humor.
Some day I'll tell y'all how he got me back.
brian john said:I have used a variety of circuit tracers with success for years. ...
