jocool1313
I have an occupancy sensor that has a max load of 800 watts. With flourecent lighting to find the total watts do I ...
1.) Add all the watts from the lamps in each fixture? Ie 32 watts per lamp 3 lamps per fixture = 96 watts
2.) use P=I*E and get P=.5 amps * 120 volts or p=.5*120 or P=60 watts?
I believe i need to use option 2 since a ballast alters the incoming voltage and that is how you can get 96 watts of power with only .5 amps.
Am I correct?
Thanks,
Joe
Am I correct?
Thanks,
Joe
