As an Electrical Engineering Consulting company that performs design of fire alarm systems, can you perform fire alarm inspections in your jurisdiction? Can Electrical Contractors? Or does the company need to be a Fire Alarm Company Contractor? Who can perform fire alarm inspections in your area?
This is just a survey, I understand that different jurisdictions require different things, that is the point, want to get an idea of the requirements around the country.
For example in NJ, to perform a fire alarm inspection based on NJ Fire Code, you need to be a Contractor. Either a fire alarm contractor or Electrical Contractor. If you are none of the above, then you need to get NICET II certified and then register with the state for a permit, you must then maintain a 24 Hour emergency line, tag all your company vehicles with the 24 Hr number and permit number. Not sure why NJ precludes Electrical Engineers from Inspecting/Testing fire alarm systems when they can design the systems.
