Should a fire department in any given municipality be able to tell remotely if a master box (that monitors a specific fire alarm system) is switched to "disabled"? Reason for this question is that a few weeks ago one of the techs I work with thought he forgot to re-enable the master box at a sight he was testing. He called the fire department upon disarming and again upon rearming the system and when he called to rearm the system, they told him it was all set and had a clear reading. I told him that he's all set because if it was disarmed, they would have a trouble or a fault reading on there system. He didn't agree and got him self all worked up and weeks later, he still thinks he's correct. Can anyone confirm who's right? Also, you should know that this is not a "long/short arm" setup, it is a simple disable/enable type disconnect.
