fire alarm troubleshooting book
JohnCA
California
The most important aspect of troubleshooting any system in general and fire alarms in particular is understanding how each component of the system operates.
a good starting point would be to familiarize yourself with the actual components of the fire alarm system (smokes, Heat, pull Stations, Panels.....), than you can use common sense and few tools to find the trouble.
one of the hardest and most dreaded trouble for fire alarm technician is the "Ground Fault", this article will explain the details and tips. http://houstonfiresafety.net/2008/08/03/ground-faults-technicians-nightmare-or-an-easy-fix/
Take a look at the following books they should get you going.
Understanding and Servicing Alarm Systems, Third Edition
ir
An old reference but very valuable if you are just starting out.
NFPA Pocket Guide to Fire Alarm and Signaling System Installation, Third Edition
ir
Must have pocket reference from NFPA.
Operation of Fire Alarm Signaling Systems
ir
Another must have for any fire alarm designer, installer and technician.
You can also try the manufacturers web site like this one:
http://www.firelite.com/support/faqs_conv_facp_troubleshooting.html
Hope this will help, You can always post your specific trouble in this forum so we can help.
John.
