JeffD
- cleveland, oh
What are the requirements for running open fire alarm cable in concealed walls? Are you allowed to run just the open cable and not in conduit in a commercial application? I can't find anything in the NEC and my nfpa72 is at home. I am used to seeing conduit to above ceiling but can't find anything saying it has to be that way. Also assuming it doesn't have to be in a raceway concealed in walls when going through metal studs or entering metal boxes I assume grommets or bushings would be required to protect the cable. Can I refer to 300.4 to back that up even though the section refers to NM cable? If not is it required and what can I point to to justify it?
