billdozier 78
 - Orlando
Had a service call to work today. Charred insulation on some of the wires inside of panel.  Only thing my lead could find after cleaning out dry chem from extinguisher was a switch that caused breaker to hum. This breaker was burnt on the area where it clips to bus bar. The hum only happened when this switch was turned on. Switch had no ground attached to it. It was located directly under the panel. There were two other switches fed by same breaker in the box. No apparent problems when these switches were turned on. Wrong breaker from a different manufacture was installed. We changed out switch and breaker. Would this be the culprit? What else would you guys have done?  One other breaker would ark when it was turned on. We changed out that breaker as well,apparently fixed that problem.
