Do we ground fire pump ATS? (i.e. run grounding electrode conductor from fire pump ats and bond to building grounding system)? Fire pump can be understood as a separate service, I assumed.
If you are thinking separate service as a (separate building) fed from your main service. Then in 08 it would need a 4 wire any way.
But it might make a difference depending on the type of generator you have.
