We will be performing upgrades on the forums and server over the weekend. The forums may be unavailable multiple times for up to an hour each. Thank you for your patience and understanding as we work to make the forums even better.
It's not in the NEC. The easiest way to find out the specifics of a particular assembly is to consult the Fire Caulk Manufacturer for their information, you can probably find it on the manufacturers web site. You will need to know the wall, ceiling, floor, or partition type and rating.
Roger, hi, this was a question on a Limited Energy test I took in Florida and am taking again this weekend coming up, the referrence they let you use is the NCE code book, they would ask a question that the answer in't in the code book?
I am surpirsed that particular question is being asked on that particular exam. I don't believe any the references permitted to be used on the exam including the NEC provide that information.
The typical UL System calls for anywhere from 1/2" to over an inch of fill depth in both the annular space around the pipe and within the pipe itself...
