Shujinko
I have a project that has ductwork crossing into fire rated chases at multiple locations. Fire/smoke dampers (FSDs) are being called to be installed in the duct work at the point where they cross into the fire rated chases. The plans show that upon general fire alarm initiation all dampers in the building are to close. This is how I've typically seen FSDs controlled here in florida. However, the mechanical plans reviewer sites the Florida Building Code mechanical section and says that there needs to be a duct smoke detector installed within 5 feet of each FSD and when it detects smoke it will close that particular FSD. There are alot of FSDs in this job and that would require alot of extra duct smoke detectors. Is there anywhere in code that says that you can close all the dampers upon general fire alarm initiation? Where is this in the code? ANy help is appreciated.
PS: This project does not require any smoke control system.
