Fire Suppression Systems
Re: Fire Suppression Systems
Neito,
I'm assuming you're talking about a hood extinguishing system for a restaurant grille area. Peter is correct. The fire alarm system interface is first and foremost. However, there is a solenoid and switching mechanism on the tank of the suppression system that will give you several sets of contacts. One set of those contacts will be used for the fire alarm system interface, another set will be used to de-activate the exhaust fan and another to activate a "make-up" air fan. Check with the fire inspector in the area you are working and he should be able to guide you. If not, the company that is providing the suppression system should know the particulars.
If none of these are knowledgeable about this you can go to the AFAA website and subscribe to their code forum. They know everything. Many of the subscribers work for Simplex and other large fire alarm companies and they consider themselves "code weenies". I don't know how they hold down a job because they're on the internet constantly.
Regards,
Phil,
Gold Star Electric
NFPA 96 is the main document.
Covers supply fans, exhaust fans, interface to fire alarm system, etc.
Thank You guys for your info.That is exactly what I will work on. besides there is some horn and strobe connection to this, well I will try to get more info on that web site. I know we all capable to wire anything up to code with the right drawings and info (even though is my first time). There are only two motors one 3/4 HP and 1/2 Hp
Neito,
I don't mean to throw a wrench into things but there's one other thing you should check into. Call your insurance company and make sure you are covered to do alarm work. When I first started out my agent told me that the insurance coverage was different for this type work and that the premiums are much higher. When alarm systems fail (irrespective of whose fault it was) lawyers like to use the "shotgun" approach when choosing who to sue.
Phil,
Gold Star Electric
Oh no. Your advise is really appreciated I will call him tomorrow to be sure although I remember he mentioned I was cover for Alarms but it's better to be sure.Thanks Phil.
