What is the code requirement for fire pump grounding.We have a 75hp 480v 3p pump with a tap
ahead of the main in the swbd thru a 600a disc sw
to the fire pump controller/ats.We also have a 175a
mag only cb on the gen set with a feeder to the fire pump controller/ats.
The feeder size is #1cu 3 or 4 wire?
If 4wire does the neutral stop at the disc sw?
Do we need 4 wire from the gen set bkr?
What bonding or ground wire is required?
