JP490440
- NW Oklahoma
I have 2 brand new guys working with me. I?ll tell you what I tell them. Get off the phone, learn to read a tape measure, don?t use my benders as hammers, Once again stranded wire has small hair like strands and solid wire is uhmm.........solid
Get a book on electrical theory, Mike holts book/ dvd is a good one. If you understand how electricity works in simple terms you can apply that to a lot of the things you do and answer your own questions.
Get a code handbook as opposed to a codebook. The handbook has lots of pictures and diagrams and is meant to be easier to understand.
You don?t have to understand everything right now, just keep busy and do a neat job. Sometimes your just not ready to wrap your head around something.
3 and 4 way switching is a simple thing. Typically there is a black screw on each 3 way. On one 3 way the black screw is the line (power in)
On the other 3 way the black screw will be the load ( light or whatever )
The other two (non green) screws are for the travelers they simply hook to their counterparts on the other 3 way switch just like the picture.
Travelers are two wires that do nothing except hook between the switches. Thats all they are for. Wether it?s 10 feet or a hundred. The black and red wires going between the switches in the diagram are travelers.
To add a 4 way or 10 4 ways you simply run your travelers from the first three way switch to your first 4 way, then run you travelers from that 4 way to your next 4 way or your 3 way.
You can have a whole bunch of 4 ways as long as there is a 3 way on each end.
4 way switches have 4 screws plus a ground two are marked input and two are marked output simply hook one set of travelers to the input and the other set to the output. It?s pretty simple once you get it. Buy a couple of 3 ways and 4 ways and make yourself a little 12v desk light with lots of switches.
