Open Neutral
- Inside the Beltway
- Engineer
Have a hydronic heating system with multiple zones. Most are controlled by wall thermostats to an uponor Zone Control and thermal valve actuators.
But in the master bath, there are 2 special zones; one is the heated towel rack. The other is the granite pedestal the tub sits within; it's lined with hydronic tubing on its own loop.
Both have the issue of "where do you put a thermostat?" The floor has one for its zone. There's no place on the rack for one, nor the tub. So my approach is to put a t-stat in the hydronic return line to the manifold. I've got thermowells with 1_Wire sensor probes in therm, but nothing like an adjustable on-off t-stat. Where should I look for such?
Suggestions?
Suggestions?
