delectric123
- South Dakota
I've run into a few situations where I need to add a receptacle a few stud partitions away from an existing one. the walls i'm dealing with are regular drywall-covered 2x4 walls. both the ceiling was totally enclosed and the floor was concrete. with a flexible drill bit you can only go through two studs before the bit would come out on the other side of the wall. does anybody have a trick for going further without making another hole in the wall? if there somehow was a way to make the bit go straight............
