jmellc
 - Durham, NC
 - Facility Maintenance Tech. Licensed Electrician
We have a lot of these bollard lights. Had to open them to swap to LED. Mounting screws in the base nearly always rust tight. Have to pry up the tube with pry bars & it damages the base.
I found a decent fix.
Cut, grind or chisel the rusted pieces from the tube.
Use a wire brush & threading due to clean rusty threads.
Get our metal shop to make hoop brackets. They drill & tap holes to match mounting holes on tube. Drill holes on top to match bolts on concrete base.
Clean & fix top parts as needed, leave long wires to bottom & reassemble top.
Mount brackets on bolts, crisscross as shown. I spaced brackets that both come down to concrete. Connect wires & place tube over brackets. Line up & secure with new bolts.
My first one was near perfect. 2nd slightly off & I could only match 3 bolts but it is still solid. I will keep using this method but tweak details as I go. It’s great to have a metal shop at hand.
This bollard is an excellent design IMHO but Lithonia should have at least used stainless bolts to lessen rusting & corrosion.
