jeff43222
- Minneapolis, Minnesota
I'm curious how other ECs price out residential remodeling jobs. I work almost exclusively in single-family dwellings built before WWII, and I do fixed bids up front. Lately I've been wondering if I should change my pricing policies.
When do you do fixed bids and when do you go with T&M? The only time I've done T&M is on troubleshooting calls (a very small part of my business). I ran into a plumber on a job today and talked with him about this, and he said his work is almost all T&M, even on remodeling work.
The reason I ask is that I'm finding that more often than not, I run into hidden snags that wind up costing me significantly more time than I planned on. For example, today I was planning on putting in a new receptacle and circuit in a kitchen, but when I drilled down through the newly-cut outlet hole with my flex bit, I discovered the flex bit was getting hung up on a rim joist, and the only way to drill down inside the wall was to open up the wall, drill down, then patch it afterward. Since the HO was out of town, I was unable to ask him how he wanted me to proceed (open the wall, go with surface-mounted conduit, cancel that task, etc.), thus causing me to stop and basically lose the day.
I'm a little concerned that if I switch over to a totally T&M model, I'll lose a lot of potential business because people are usually leery of T&M billing, as it can get out of hand very fast, and it's much harder for them to know if they are being ripped off. My fixed-bids model is bringing in plenty of business, but I'm not making nearly as much money as I think I should for all the work I'm doing.
[ July 14, 2005, 07:06 PM: Message edited by: jeff43222 ]
