- Massachusetts
If you look at this as only an electrical problem the fix is simple and easy.
Electrical is what I am hired for.
Sloping floors not my problem unless they are so bad my coffee spills .... If that happens look out.
And jacking/shimming should have taken place before drywall was installed. It likely will need repaired afterward if that is what will happen.
Chances are floor will be shimmed to level it and new subflooring installed. At very least cabinet installer will most likely shim their cabinets so they are level.
With that kind of slope maybe that room was once an old porch and intentionally had slope to drain any water??
Sloping floors not my problem unless they are so bad my coffee spills .... If that happens look out.![]()
Again. I never suggested that the slopping floor was the OPs problem. I did suggest that he talk to the owner or builder or whomever is running the project to see what if anything they are going to do about the slopping floor.
If they say they are going to do nothing and just leave it that way so be it. You level your boxes and call it a done deal.
If they are smart enough to level that floor before going any farther you let them do that before you attempt to level your boxes. The level of the counter top is going to determine how your boxes look.
