Fixture Box
mstrlucky74
NJ
Not exactly sure what type cast box would be used in this situation. A little confused by spec(see below). Also attached detail pick of fixture mounted to the cast j-box. These are parking garage fixtures.
Boxes for lighting fixture installation shall be 4-inch square, minimum 2 1/8-inch
deep, and provided with 3/8-inch studs.
Unless otherwise shown on the Contract Drawings, provide galvanized,
code-gauge, sheet-steel junction and pull boxes and covers for interior locations
and cast-metal boxes and covers for exterior locations of types, shapes and sizes
to suit each respective location and installation, and equipped with stainless steel
hinges, nuts, bolts, screws and washers.
Interior boxes would just be standard 4 x 4 squares. RGS is wasted with these IMO.
Exterior would probably be FS/FD for use with RGS from your other thread.
The studs mentioned are usually a bracket and a piece of "lamp" thread that comes with the fixture or can be purchased separately.
Not sure that interior parking garage boxes would be standard stamped steel 4x4 boxes. Think they are referring to(both detail and spec) WP type box.
I am not seeing that. sheet metal boxes are stamped and FS/FD boxes are cast. Bell boxes are cast also, but are aluminum IIRC.
