A popular installation on new houses in this area involves the "pop in" LED fixtures where the driver and j box are connected to the luminaire by a factory cord.
Slack romex is left above the sheetrock ceiling and holes are cut for the fixture once the desired location is determined, romex is connected to the jbox which is then placed on the sheet rock and the fixture installed in the hole.
On the surface this seems to meet 410.118 as the j box is "part of the fixture" but the box ends up not securely fastened and the Romex is not secured within 8" of the box yet these routinely pass inspection.
Is there a method to install these and comply with the NEC,
