Alwayslearningelec
- NJ
- Estimator
For those who estimate how do you approach laboring fixtures mounted on high ceiling? Say above 15’ working off lift. Do you apply labor factor/increase labor?
I would simply assign a time allowance per light, to include any furniture moving, as well as time on the lift, plus the lift rental itself.
Some lifts allow the lift to move when the platform is elevated...Are you thinking that the lift is faster or slower than using ladder?
slowerAre you thinking that the lift is faster or slower than using ladder?
You need to rethink that.slower
why. it's faster ? no matter what being installed off a lift?You need to rethink that.
The learning curve gets remarkably less steep when you finally read the fine manual! "Oh! You put the base plate up and THEN you install the driver!"For me hanging fixtures is one of my least favorite jobs. But, usually the first one (for example )takes 25 min the next 20 min then your doing the rest in 15 min theres a learning curve r to everything......at least for me.
10'-15' ceiling height add 5%. As the ceiling gets higher, so does the labor.
Thanks. This is contrary to what other here say...some say it takes less time.
Who said that? That doesn't even make sense.Thanks. This is contrary to what other here say...some say it takes less time.
Yep......Estimating 10110'-15' ceiling height add 5%. As the ceiling gets higher, so does the labor.
Limited experience bidding these projects but both methods take longer because of the height. The lift reduces the time over the ladder.Thanks. This is contrary to what other here say...some say it takes less time.
