A Alwayslearningelec Senior Member Location NJ Occupation Estimator Mar 25, 2024 #1 This fixture is 14"x17" and roughly ~58lbs. Beingh installed outdoors under a roadeway deck via lift. Assuming once strut/support system is mounted and fixture is ready to be mounted to it TWO people are needed due to it's weight?
Seven-Delta-FortyOne Goin’ Down In Flames........ Location Humboldt Occupation EC and GC Mar 25, 2024 #2 I’ve rigged up a platform or stand in the basket of my lift to hold fixtures for mounting. Even laid 16’ long 4x12 wood beams across the basket and lifted them into place myself, on a 3 story deck. Just depends on how creative you want to get, and if you have a helper available.
LarryFine Master Electrician Electric Contractor Richmond VA Location Henrico County, VA Occupation Electrical Contractor Mar 25, 2024 #3 Alwayslearningelec said: This fixture is 14"x17" and roughly ~58lbs. Beingh installed outdoors under a roadeway deck via lift. Assuming once strut/support system is mounted and fixture is ready to be mounted to it TWO people are needed due to it's weight? Click to expand... Definitely two people or a mechanism of some kind.
