Alwayslearningelec
- NJ
- Estimator
Cut attached says 33W but it also says fixture can handle 100 to 277VAC so wouldn't the wattage be different depending on the voltage?
Actually I think I'm wring now that I think about it. When you calculate to get the AMPS you use whatever voltage it is which will give you varying amps.
277V would give .1191 amps
120v would give .275 amps
