five.five-six
- california
I have a job to install a small generator on a roof. The roof it about 12" thick concrete deck with asphalt cover. How do I go about flashing the penetrations on such a roof?
Have a roofer install a pitch pan. That way when it leaks, his phone rings.
And then just run all my conduits through the same penitration?Have a roofer install a pitch pan. That way when it leaks, his phone rings.
The company I work for would not even think of doing this ourselves. We would hire a roofer to do it and take on the liability.
Same here. Flat roofs are even trickier than residential pitched/shingled roofs.
I'd have the roofer there before you start core/hammer drilling the roof.
Don't make the hole. The roofer makes the hole.
I have a coring contractor to make the hole... I didn't think roofers did that.
If it's post-tension and he cuts one, it can get nasty (tendon separates in two and accelerates out each end of the building creating a very dangerous situation).
Can you provide any link to that happening?
I have seen a number of these cut and they have never moved a bit, they are held fast by the concrete.
Now of course they should not be cut and structural engineers where required to design a fix for the reduced strength but I have never heard of the cables moving.
