T
T.M.Haja Sahib
Guest
Good.
Now what can you ascertain from that in relation to the first point in your post #72?
Sorry.I am not able to continue in this thread,because the OP is disturbed by my technical deliberations...........
Good.
120119-0932 EST
iwire:
As a means of communication I need to know where you have questions, and then I can try to provide some way to clarify to you what I am saying.
I don't know if this will help or confuse, but I'll give it a go anyway.Most of it but that is a problem with me and not your explanations.![]()
have used Dranetz analysers when they were a bit less portable. I always thought it was good kit if a tad expensive.It just dawned on me that Gar and others might be interested in what meter is being used.
This is it here. http://dranetz.com/portable/powerxplorer-px5
Completely agree.120119-1120 EST
If there is any way to see what is failing in the ballasts that would be very useful information. Has the diode bridge shorted, has the filter capacitor shorted or opened, has a copper trace between the bridge output and the filter capacitor burned up, is there an MOV at the input that failed?
Completely agree.
The nature of the failures could shed some light on the cause of them.
Appreciated, sir.Pictures help me a lot, thank you.
I feel quite sure that your erudite, instructive, constructive, and informative contributions demonstrating the breadth and depth of your profound knowledge, prowess, and practical experience on these matters will be sorely missed here.Sorry.I am not able to continue in this thread,because the OP is disturbed by my technical deliberations...........
Not sure you'd call it a DC bus. CFLs have an input rectifier - as do may other pieces of electronic kit. Gar has kindly provided a link to such input circuits.I just had a thought. I wonder if the flat tops are causing the DC bus to get low voltage. Do flourescent lights have a DC bus?
Kind words, thank you.I also would like to thank you guys for this thread and discussion, especially iwire, Gar and Besoeker.
120120-1501 EST
simple 5 tube radio
