sceepe
Flex cord and plug section is pretty clear that flex cord and plugs are not allowed to be routed through holes in walls. There is exception if routed in raceways. (Sorry I don't have the code section)
I commonly see 6" conduit sleeves installed in walls to route communications cables into adjacent rooms. Would a flexible power cable be allowed to be routed in such a conduit sleeve and plugged into receptacle in an adjacent room. (Assume the power cable is not in the same conduit sleeve with the data)
I would think not because unplugging of a device is a means of disconnect. If it is plugged into and outlet on the other side of the wall, you can't easily unplug it. However, I can't find code to back me up.
What do you think?
What do you think?
