in article 400 it addresses flexible cords and in 400.8 "Uses Not Permitted" (5) "Where concealed by walls, floors, or ceilings or located above suspended or dropped ceilings" I take this to indicate any ceiling mounted equipment such as TV's, Projectors, etc with cord an plug connections are prohibited from routing their "cords" thru the mounting device to a receptacle above the suspended (lay-in) grid ceiling system, a receptacle flush in the ceiling is acceptable and even a receptacle above the ceiling space is acceptable but not the "cord" connecting the equipment to the receptacle if routed above the grid. Does this sound correct? Are there any exceptions other that those listed in 400.7 anywhere in the code I am missing??
