publicgood
- WI, USA
I ran across this Mike Holt image showing flexible cords being plugged in below a raised floor and above a drop ceiling. It notes this to be okay for raised floors, but not drop ceilings. The reference is to 400.8(5) with emphasis on the definition for "concealed."
Is the assumption here that the raised floor has a protective grommet and the drop ceiling is just a hole through a ceiling tile? Would it be different if the tile was just lifted and cord snaked through (leaving the tile slightly open)? I feel like I've seen a graphic for ceiling mounted projectors not being allowed to have their receptacle above the ceiling.
Note: Often raised floor tiles are screwed down, rendering the underfloor not readily accessible.
Looking to hear thoughts on this subject and also how it may relate to 400.8(2). I would also highlight that 400.7 does not give below a raised floor or above a dropped ceiling as a permitted use.
http://www.ecmweb.com/code-basics/cords-and-fixture-wires
http://www.ecmweb.com/sites/ecmweb.com/files/uploads/2004/04/404ecm17fig1.jpg
