Any thoughts on the following.
240 volt floor heat that has been operational for 5 years.
Abruptly stopped.
Ohms readings are within Mfgr specs
Voltage input correct.
T-stat was swapped with one that’s operational in another part of the house.. Did not heat with that either.
Haven’t seen the job. This info is from the owner who had a reputable electrician look at the situation.
Thanks
Abruptly stopped.
Thanks
