TMMB said:Kindly , I WOULD LIKE TO KNOW , IF GFI CIRCUIT BREAKER IS REQUIRED FOR FLOOR MOUNTED RECEPACLE CIRCUIT ACCORDING TO NEC .
Regards
Are you YELLING? :grin:wireguru said:i would use GFI, if your computer is plugged into a non gfi floor receptacle the ground fault currents can CAUSE YOUR CAPS LOCK KEY TO STICK
ItsHot said:Are you YELLING? :grin:
I need to remember to put my coffee down before reading future posts.....:grin:wireguru said:i would use GFI, if your computer is plugged into a non gfi floor receptacle the ground fault currents can CAUSE YOUR CAPS LOCK KEY TO STICK
