Alwayslearningelec
- NJ
- Estimator
For same size core and same thickness wall and slab would you say it takes about the same time to do a wall core as a floor core?
Thought it's always wet???Wet or dry core?
There are both types. Wet is more involved because you need water but dry is fairly useless if the concrete has a lot of rebar and you're coring large holes.Thought it's always wet???
There are some brand new bits coming out that are advertising Dry bore.Thought it's always wet???
