Flourescent ballast troubleshooting
mdshunk said:
"Tune up". Thank you. I might borrow that. Laymen can relate more to the term "tune up" better than "ballast replacement".
Customer- "What does my light need"
Me - "Nothing besides the ordinary tune-up parts."
Paul used that term towards you, as a senior electrician, familiar with the lingo.
That term used with a customer you could be inviting a mis-interpretation
and lose the customer over the appearance of 'scamming'.
glene77is
Since the original post was about ballasts in signs, I thought about some of the signs I've worked on, and some of the responses I've seen in this thread. A lot of signs will have more than one ballast. It's not uncommon to work on a sign that has 3 or 4 six lamp ballasts. I always look at the lamps first (that is, after checking the line voltage), and will replace all lamps if the sign has been opened (with the owner's permission, of course). While the lamps are out, I inspect the sockets (always HO's in outdoor signs), especially in the bottom of the signs if mounted vertically. If suspect, I'll open the raceways to look for burned up or pinched wires. If the ballast is singing a pretty tune, or is extremely hot, or the label or paint is off color, suggesting extreme heat, I'll replace the ballast. Only in these cases and if replacing lamps, and the sockets and wiring look good, but still no lights, will I replace a ballast. They should last at least 5 years, and do sometimes last a lot longer.
I wasn't aware that the voltages at the sockets could be metered. Thanks for the tip, iwire. It's printed and will be on my truck tomorrow.
good practise is to replace lamps and ballasts cause you know
the ballast is fryed from trying to light up the old lamps and will
quit.
jmo
They used to make a tool that would check the lamps, you touched it with a wand and it would or wouldn't light tell you if it was the tube. Of course if it lit it was the ballast. I used to hate replacing ballasts, but I do agree with some of the other posters you're in there you might as well fix or replace everything and save a service call.
