Take and Advance ICN-4S54-90C-2LSG ballast for instance that has the option to operate (2) of the lamps if a switch is installed between the incoming neutral conductor and the Red/Grey lead of the ballast.
Would you pull (2) white (or grey) neutral conductors down to the wall switch since in actuality we are switching the neutral if its 120v?
To me, by rights you should, but, seeing 2 white wires terminated on a wall switch seems odd.
