wptski
- Warren, MI
Spotted this in another forum: Safety Recall
"The voltage indicator red light can fail to illuminate, which can mislead a user to believe there is no voltage in the circuit that is being measured."
What if it happens to fail after the live/dead or sometime inbetween??From the recall notice-
To me, this is a non-issue. First, a live-dead-live test would notice this, and second this is the wrong tool for checking to see if something is dead!!! It's a great tool to see if a wire is live, but that's all.
I will agree that joe homeowner (and unfortunately a few people in the trade), don't understand this, and if I had any of this model, I'd follow the recall because it's official. OTOH I wouldn't worry about my own safety.
I absolutely agree with the first part, but I disagree with the second.From the recall notice-
What if it happens to fail after the live/dead or sometime in between??l!
But there are common conditions that can cause the proximity tester to give a false negative. If your known live test does not exactly match the conditions of the conditions of the item to be worked on you could be in for a surprise....
Given the simplicity, compactness and lower price, the proximity tester is more affordable, therefore it will gain wider use.
For some people the proximity testers do not work well if yo are on an insulated ladder and they also don't work well if you have a cable wiring method that contains paper under the jacket and the paper is wet. That being said, if you understand the conditions that can give false negatives, they can be an excellent tool. Also other testers can also lead you to believe that there is no voltage when there actually is. It all boils down to the fact that you actually have to have some idea of what you are doing to be an electrician.
Here is power point presentation on some of the issues with TBT. Slide 11 talks about some of the issues with proximity testers.
