M1sacs
- Duluth, MN
I'm looking into ways to see if I can tell when a lighting fixture has a problem..? Does a Ballast that is burning up use more amps? does a bulb that's starting to go bad use more amps?
I have a Classroom with about 12, 4 bulb fixtures and I have a Current transducer on the circuits, so I'm trying to know how to tell the maintenance dept. that the room has an issue without having to go to each room or be told by a worker that a bulb or fixture is out.
