Fluorescent lamps flash on, then turn off
mark32
Currently in NJ
Hello all,
Today I changed lamps in a two lamp G24Q-3 fixture because the existing lamps (LED replacements) had a slight and odd flicker to them. I noticed the lamps were pretty darn warm, approaching hot, when I removed them, almost couldn't handle them with a bare hand. Anyway, I put in some new LEDs, but they didn't work. I then changed the ballast, and when I turned the switch back on, the lamps flashed on for maybe two seconds and went off. I tried another brand of LED'S along with a set of fluorescent, but they all did the same thing. I had to leave it as is for the time being, but will investigate more tomorrow. Any idea as to what is taking place here? Full disclosure, I did not take any voltage readings.
Wrong ballast for direct replacement LED’s. Get rid of the ballast and use direct wire. Even easier than changing the ballast in most fixtures.
Yeah man, I do electrical maintenance for a hospital and I told my boss we should go that route going forward. As it stands though, even the fluorescent lamps acted the same way. Oh well, I'll dig into it a bit more tomorrow. Thanks!
My first guess would be mismatched ballast/bulb combo. If you can go with led bypass, it’s the way to go. It’s actually faster than replacing a ballast, and you’ll never have to worry about it again. As long as the tombstones are in good shape.
OK this may be a stretch but have had a wiring short that only opened after a load was applied, without a load the meter saw 120V, add the load the meter rapidly dropped to 0V over very short time, maybe 15-30 sec. Such could be in OP case, as heating can be sign of high resistance on the wiring.
I agree with most to use a bypass LED vs a ballasted one, why even use a ballast type as other than possibly a slightly lower power consumption you've saved nothing. The ballast still consumes, and the ballast is still another point of failure and replacement.
Sounds like it may be a shorted socket since changing the ballast didn’t help. Or a wire popped out of the socket.
Thank you all for the replies! And hillbilly, when you're good, you're good :) It turned out that one of the leads coming from the ballast had indeed popped out of one of the sockets! You da man!
Bypassing ballast seems dangerous. They are there for a reason?
Think "removing" the ballast, whether physically or electrically.
Almost all LED tubes don't require a ballast just like other LEDs.
For the lazy or unqualified, some LED tubes can run on ballasts.
Yea i wasnt referring to LED bulbs so much but removing ballast for florescent bulbs.
I belelieve the ballast step up voltage while limiting current
An LED bypass bulb is an LED though.
I remove the ballast and rewire the fixture for direct connect LED bulbs.
Fluorescent bulbs won’t work without a ballast.
