How do you generally calculate fluorescent lighting loads. I have seen designers simply take the wattage of the lamps and multiply by the # of lamps. Might okay for a rough calculation, but not accurate when you get say 50 fixtures on a ckt. I use different lighting layout software programs, which supply me with fixture data, usually indicating that the fixture is listed at a lower power requirement than the lamps. i.e. Two-32W T-8 industrial strip with electronic ballast ? 58 W. How can I explain this better / understand it myself.
