The manufacturer has a limitation on the length of conductors the the dynamic braking resistors use to connect to the drives D.C. Bus. The smaller the drive the smaller the length can be. Why is there a limitation on the dynamic braking resistor conductors? I understand for the conductors on the output to the motor due to the reflective wave phenomenon. But why for the D.C. bus/dynamic brake?
Second question is, let's say you have two flux vector drives load sharing. You mount the DBR for drive 1 roughly 2 times as far as drive two. Does the change in electrical characteristics of the dynamic brake ckt change the performance/ load sharing of the drives?
