In earlier code versions, flexible conduit with 5 inch size could have been used and then code limited it to 4 inches. Why was this change made? Some types of flexible stainless steel (not interlocked armor) piping has been used for flexible steel conduits on numerous projects at various sizes very acceptably with good integrity. If one is using 5 and 6 inch conduits, the same sizes of flexible should be allowed if it meets integrity, strength, and its other intended purposes without damage to cabling or conduits. These other than interlocked cable are also provide excellent sealing against liquid intrusion when they are welded or used with good threaded fittings.
I currently work on a project that that has the 1987 code as its code of record on a power plant where the code is being implemented by a foreign country. The owner is questioning whether the 5 inch flexibles should be removed due to the exclusion in the 1999 and later codes. I know that code does not apply to power plants, but this question requires a response as to why the size limitation. I can understand not wanting to use large interlocked armor conduit, but not other high quality configurations of steel flexibles.
Does anyone have reasons other than integrity and strength of the flexible for supporting and handling pulling cable,including sidewall pressures, without damage to either the conduit or cables? Any background or other information on this subject would be much appreciated.
Thank you very much in advance.
