Can I use FMC as a wiring method ?
Can I use Lfmc as a wiring method?
(While doing this I also drilled into a live 1/2" cold water line but thats another story![]()
You did???
Sure did, took a big chunk out of the pipe with a 1.5" Hole saw. The 1/2" I hit was only a few feet from the 1" main supplying it so I had a lot of water fast. Luckily the valve was nearby and it was just the bakery at a S&S. Fixed it myself with 'Sharkbite' plumbing fittings from Home Depot.![]()
Nice, those fittings are great for screw ups....err...I mean emergencies like that.
Did you run the zamboni to clean up the water too?![]()
You figure that on the plumbing forums those are talked about like backstabbing and Wagos are here?![]()
There was a floor drain so I just used a big squeegee.![]()
Aren't we supposed to de-energize pipes before drilling holes into them?While doing this I also drilled into a live 1/2" cold water line but thats another story![]()
Part of the run is concealed (suspended ceiling) and part of the run is exposed.
