mark32
- Currently in NJ
Have you ever questioned manufacturer torque specs? Most of the time the specs seem to feel "Right", other times the specs seems too little or too much. I've stripped out a couple of switches in the past well before arriving at the specified torque. Other times the torque doesn't seem to be enough to hold the conductor well enough in it's terminal. Today I terminated a #12 copper to a ground bar in a Siemens panel. The labeling said to torque to 20 in lbs., which I did but didn't like it so I went up to 22 in lbs and then removed the conductor to look at it and it looked great, two little dimples. I cut it off and torqued it to 22 and then another little smidgen with my regular screwdriver because, again, it felt right. 20 in lbs feels fine on #14 but not #12. The breaker (Siemens) has the same type of terminal setup as their ground bars but recommends 25 in lbs, what's up with that?
