drcampbell
- The Motor City, Michigan USA
- Registered Professional Engineer
If you were to use a 3PDT-center-off switch, the first two poles could reverse two of the motor leads and the third pole could be used for controlling the contactor. In the up position, the motor runs forward continuously; in the down position it runs in reverse but only while the operator hold the pushbutton down.
A hesitation switch will assure that the motor's de-energized before being reversed.
