CarlAshcraft
- Orlando, FL
I finally got approval from a customer to replace an Old 100amp FPE panel. The panel is located in the customer's kitchen. When I did the original walk through, I obviously didn't take a close enough look at what the situation was. The panel is a small panel (approximately 12" wide). The problem I am having is the panel is located between Rigid conduit (feeds the upstairs condo) and a door frame. Unfortunately there is a pantry located to the left of the panel and a door way to the right of the panel. Here is my stupid question, Is there a panel available that is 12" wide? I forgot to mention that the panel needs to be a 20 circuit panel.
