chris kennedy
- Miami Fla.
- Retired electrician
iwire said:That is nuts.![]()
chris kennedy said:I take it you haven't seen one before. How old were you in 71?
But you can talk to 'Exciting people 24 hours a day'.mdshunk said:I just called the number, so I'll save someone else the effort. It's now a "talk line".![]()
Yes, I posted a picture of a copy.480sparky said:So why are you still here?![]()
Chris, does the label look like it's original?
Yes, it makes me feel young, I was 11.(I was 12 in '71, if that helps).
chris kennedy said:Yes, it makes me feel young, I was 11.
electricalperson said:so what are you going to do now that you found the label?
i ment as in the job. will you replace the gear?chris kennedy said:Sell it to a collector. Bidding starts at 1 Bud.
I'm not worried about two 3? 208V 50A breakers in this panel. It's not service equipment. Soon to follow, a pic of the 4000A FPE main I have to open then close in the same room.electricalperson said:i ment as in the job. will you replace the gear?
chris kennedy said:Here is the 37 year old 4000A main I have to throw. I know it has been opened and closed once before as I am the second guy that had to tap this gear.
Any heads ups?
Buttons don't seem to be an option here. Note the gear says discharged. I have never worked on this type and have not done a visual inspection of the mechanism yet.peter d said:Use a very long pole?
