Free software
Basra123
Hello,
I am looking for free software to graph trignometirc functions such as sine and cosine and the rest???? any help !!!
Re: Free software
fyi, Excel defaults to radians not degrees.
Just remember to convert within your formula if you want to work with degrees.
Re: Free software
Hi,
do I need a special add-in such as Dplot to graph these functions? Can some one show me a simple example?
I tried to use the sine function but this only return a number and won't plot the sine function itself? Thanks1
Re: Free software
The last time I needed to plot a trig function, I created two columns in Excel. Column 1 was the degrees from 1 to 360. Column 2 was the trig function of Column 1, taking into account the conversion from degrees to radians. Then I used the Excel plotting tool to get the graph that I needed.
If there is a more elegant way to do this, I wouldn't mind hearing the news. But that is the only way I know how to plot a function using Excel.
Re: Free software
I would start in a colum a enter 1 in the 1st row, 2 in the second, and 3 in the third. Then highlight a lot of cells in a colum and select "Edit" and "Fill" and "Series". Excel will enter 4,5,6 and so on.
Then in the next column, enter "=sin(" and then select the cell with the "1".
Select teh cell with the sine function, and select copy. Hightlight all the cells under it and enter paste.
Now you have a lot of points you can chart.
Steve
