Probably not the right section but no other section really looked appropriate either. Someone will hopefully know the answer.
I'm sure lots of you have heard of this, I've heard of this several times but never been there to check out the problem.
People claim to have fixtures that burn out bulbs often or have one bulb that burns out often. My neighbor claims that their light fixture in their kitchen (5 blub fixture) has one bulb that burns out about once a week (the same bulb). Like I said I haven't looked at it but electricly it doesn't make much sense to me. It would seem you either 1.have the connection of line voltage to the bulb, 2.you don't have the connection or 3. you have some kind of resistance.
If you have a good connection the bulb will light and function normal,
If no connection, no light.
If there was resistance the bulb should be dimmed (which it isn't) and should actually increase in life.
So, thats how I see it. I would think it would take a higher voltage at the bulb to cause the life to be shortened, and in a fixture such as this all 5 bulbs should have the same problem.
So, do these people have an over-active imagination. Does this really happen and what causes it? It really doesn't matter but it bothers me if it happens and I can't figure out why. I probably need to get a ladder and my meter and head to my neighbors house but I'd rather find out on here.
Thanks in advance!
Thanks in advance!
