chris kennedy
- Miami Fla.
- 60 yr old tool twisting electrician
All the equipment here is new, recently energized service. Notice anything odd?
Serious lack of phase tape.
I took it off to open it.:roll:No lock on the CT cabinet.
Bingo, POCO couldn't make up their mind, a few dollars worth of materials wasted sticking up through the roof.What are the OH pipes for?
Meter base grounded as per POCO.No grounding to meter.
Don't tempt me.Al and shovel missing.
Load side EGC?
can't see for sure but were are the meyers hubs
Didja cut the lock of the meter socket as well?
Does anybody not do that?
Well, if he's gonna cut the lock off, the least he could do is take the front off so we can scrutinize the work inside.
The only work I do in a CT meter base is 4 tapcons, a lock nut and a bushing. The rest is all POCO.
Where is the funny looking block that is supposed to connect the white wire to the smaller green wire? not to mention the bare wire that goes to the copper stick pounded into the ground???
The whole thing looks odd to me.
Here, the POCO feed would be 4 wire (no egc) and there would be a disconnect there.
So....these feeders loop thru the CT can and they wrap the CT's around them uh? The disconnect is at the panel inside?
