from mikes news letter
480sparky
Iowegia
Only time I've seen a problem with it is when guys use their zillion-volt MegaTorque cordless drill to tighten the screws. I'll keep using my 10-in-1.
frizbeedog
Oregon
Authored By Richard Zulch?
zdog said:
i was doing a search about 3/8 nm connectors from another post.this came up first.has anyone had problems with 12/3 and 3/8 nm connectors?seems like this guy was worried about it.or am i just misreading it(wont be the first time :grin: )if this has been discused sorry.
http://www.mikeholt.com/newsletters.php?action=display&letterID=319
Question: Who is Richard Zulch? Waht is Zulch Labrotories, Inc.? My search turned up nada.
What's his angle?
As Long as there are suitable plastic connectors, I won't worry. And if I had to use the other....workmanship man, common sesne man.
walkerj
Baton Rouge
Power tools have their place.
I don't see any need to use the drill for that.
I'll stick with the 10-in-1 also
mivey
When you guys get old and busted up like me, the drill can make you feel a lot younger. I just can't hold out like I used to. It is all in the skill of the drill.
Ed Carr
way upstate NY
I actually ran into this on a large resi I did several years ago.Had two shorts as a result of the NM connector & 12/3. Don't recall the brand but it had a little round dimple instead of the usual flat bar on the strap.I also did not use my Binford 88Volt Lithium/Plutonium cordless either!
PS that would be the chrome plated one :grin:
mivey
What about the Binford Ultra Mega Extreme Monster Excessive 999oz Hammer that pinches the wire under the staple?
480sparky
Iowegia
(Insert simian grunts here)
BTW, Tim has his own MySpace page.​
e57
frogneck77 said:
Some people never learn what all those numbers mean on a cordless drill-AKA-CLUTCH
Some people never realize what the long skinny thing in their pouch is for... (Get you minds out of the gutter... A screw driver!!!!) Easy to use and the batteries never die... (Well almost never...)
Anyway.....
I wonder what kind of informal testing has been done to find out how long it takes to cut a cable in half with a set screw connector and an impact driver?????
mivey
Anyway.....
I'm not as durable as I used to be. A long day of steadily turning a screwdriver and I am in some serious pain and cramps (Midol doesn't help:grin: ). The screwgun allows me to hold out longer. As with all things, you just have to be careful. I can damage wire with a screwdriver too if I'm not careful (well, maybe in the morning when my Wheaties are at full strength).
