I have a residential electrical panel that is installed in a attached garage on a outside wall. The garage is insulated and sheet rocked but not heated. I tried to remove one breaker and found it was stuck to the breaker above it. I removed both breakers and pried them apart. I found Ice between the two breakers. I am assuming the ice was caused by the condensation produced when the breakers get warm when there is a current draw? Am I correct? How Bad is this? I know water in a panel is not good but is this a common issue? I found no indication that water was leaking in from somewhere.
