bigsid
- FORT WORTH, TX
I have two self serve fuel dispensing units side by side outside and each one has a factory made panel box that's not explosion proof that are rated 30Amps, 208volts. There's a hard-usage cord coming from the panel box down to a explosion proof box that's for the terminal connections from a feeder panel outside. This doesn't seem like a class 1 div. 1 location to me. Is it possible to run liquid-tight flexible metal conduit with approved fittings just for flexibility areas coming from that junction box for this connection or should i run TYPE TC/CIC OR TYPE MC-HL cable.
I know i have to put seal fittings on because this is coming from a feeder panel outside. Tell me what u think about this job.
This is an overseas project.
